About oData service error.
Hi Expert.
Recently we need provide the data for power bi, but when we connect to odata url, the nas will be stopped. , i checked the system event viewer. the error message below:
Server instance: DynamicsNAV90
Tenant ID:
User:
Type: System.InvalidOperationException
Message: A property with same name 'No' already exists in type 'NAV.ERPPOCSale'. Please make sure that there is no property with the same name defined in one of the base types.
StackTrace:
at System.Data.Services.Providers.ResourceType.AddPropertyInternal(ResourceProperty property)
at Microsoft.Dynamics.Nav.Service.ODataServiceProvider.ODataMetadataExtensions.GenerateResourceTypePage(String name, String nameSpace, Int32 objectId, MetaPage metaPage)
at Microsoft.Dynamics.Nav.Service.ODataServiceProvider.ODataMetadataExtensions.AddPageServiceMetadata(ODataMetadata metadata, String serviceName, Int32 pageId)
at Microsoft.Dynamics.Nav.Service.ODataServiceProvider.ODataMetadataProvider.CreateResourceTypesForPublishedServices(NavSession session)
at Microsoft.Dynamics.Nav.Service.ODataServiceProvider.NavServiceHelper.ExecuteOperation[TResult,T1,T2](String companyName, ODataOperation`3 operation, T1 parameter1, T2 parameter2, Boolean isDefaultCompanyRequired)
Source: Microsoft.Data.Services
HResult: -2146233079
But the soap web service is ok.
such as :
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="1" name="Key" type="xsd:string"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Document_No" type="xsd:string"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Line_No" type="xsd:int"/>
<xsd:element minOccurs="0" maxOccurs="1" name="No" type="xsd:string"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Description" type="xsd:string"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Quantity" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Unit_Price" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="VAT_Percent" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Amount" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Amount_Including_VAT" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Quantity_Shipped" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Quantity_Invoiced" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Quantity_Base" type="xsd:decimal"/>
<xsd:element minOccurs="0" maxOccurs="1" name="Unit_of_Measure_Code" type="xsd:string"/>
</xsd:sequence>
any suggestion will be appreciated.
Related
Recommended
