Dear all,
I had a function to copy data from 1 recordref to another.
I'm trying to copy a specific field but it's not ok.
Here's my code, it does not show error but it copy all the other fields (with the default value!). Please share your ideas about this?
FOR i := 1 TO FromTableRef.FIELDCOUNT DO BEGIN
FromFieldRef := FromTableRef.FIELDINDEX(i);
IF FromFieldRef.NUMBER = 'specific Field ID here' then
BEGIN
ToFieldRef := ToTableRef.FIELDINDEX(i);
ToFieldRef.VALUE := FromFieldRef.VALUE;
END;
Thanks and best regards,
Dear Mr. Erik,
Thanks for your reply, here is my full code to copy.
FromTableRef.OPEN(TableNo, FALSE, FromCompanyName); ToTableRef.OPEN(TableNo, FALSE, ToCompanyName); IF FromTableRef.FINDFIRST THEN REPEAT ToTableRef.INIT; FOR i := 1 TO FromTableRef.FIELDCOUNT DO BEGIN FromFieldRef := FromTableRef.FIELDINDEX(i); // filter here IF FromFieldRef.NUMBER = 'specific Field ID here' then BEGIN ToFieldRef := ToTableRef.FIELDINDEX(i); ToFieldRef.VALUE := FromFieldRef.VALUE; END; END; UNTIL FromTableRef.NEXT = 0; ToTableRef.CLOSE; FromTableRef.CLOSE;
What I mean is you don't need to loop all the fields just to get one field.
FromTableRef.OPEN(TableNo, FALSE, FromCompanyName); ToTableRef.OPEN(TableNo, FALSE, ToCompanyName); IF FromTableRef.FINDFIRST THEN REPEAT ToTableRef.INIT; FromFieldRef := FromTableRef.FIELDINDEX(SpecificField.FieldNo); ToFieldRef := ToTableRef.FIELDINDEX(i); ToFieldRef.VALUE := FromFieldRef.VALUE; ToTableRef.MODIFY(); UNTIL FromTableRef.NEXT = 0; ToTableRef.CLOSE;
