How to rotate text box in 360 degree in rdlc report.
I experts is there any idea to rotate text in 360 degree because in WritingMode there is no any privilege to rotate 360
Thanks in Advance.
  • Hello Pravin,
    As of my point of view, 360 degree is the same (default) view of your text. So no need of rotating in 360 degree.
    If you need string reverse then use the following expression :
    =StrReverse(cstr(Fields!name.Value))
    I hope it will be helpful for you. If yes then please verify my answer.
Related
Recommended
