XMLport - filter sales line using sales header field.
Hi
I have created an XMLport which should export Posted Sales invoice lines in CSV format. the invoice lines should be filtered using salesperson code from the header table.
I have kept only sales Invoice line dataitem(node) and filtered the lines using below code in onaftergettrigger.
IF SalesInvoiceHeader."Sales Person Code" <> 'FH' THEN
     Currxmlport.SKIP;
The above code works fine. but it takes long time to run the xmlport due to huge no of records in sales invocie line table.
If I add new sales invoice header dataitem(node) and make it as parent to sales invoice line dataitem and filter the header row using tableview property I face two issues.
1. Blank row gets created in csv for every header record.
2. only last header's line information only show in csv.
Please advice.
Related
Recommended
