Duplicate values generating while exporting to excel from NAV
Hi guys I could see duplicate values generating while exporting to excel from NAV report. In Live environment I could see these duplicate data issue but however when I run in test environment data is generated to excel without any duplicate values.
Data is generated from item and item vendor table to excel sheet.
I believe its not an issue with coding since comparing the code between live and test had also no difference.
Debugging this is actually not possible I believe since it takes almost whole day. Because excel buffer table takes inserting one cell data per each iteration and we've around 1000's records.
Is there any setup changes needed or is it any data related issue? I believe there's no changes needed from coding side. Please let me know your valuable suggestions.
Related
Recommended
