NAV2017 - Web Service - Sub Page - Filter RecordID
Hello everyone,
I have a card-page which contains among others a sub-page. I need to filter this sub-page via a RecordID filter being able to filter by code as a record ID can't be linked via a SubPageLink Property.
The code in the card page is as followed:
In the OnAfterGetCurrRecord Trigger:
CurrPage.BMGTicketingTranslationList.PAGE.SetRecLinkFilter(Rec.RECORDID);
Here is the filter in the sub page:
SetRecLinkFilter(RecId : RecordID)
SETRANGE("Record ID", RecId);
CurrPage.UPDATE(FALSE);
All this works properly in the RTC client. But I need to publish the page as Web Service and unfortunately under these conditions the RecordID filter doesn't work.
As a result I receive all data-sets in the sub-page hence the filter has been ignored.
If I debug the Web-Service, the code is run correctly, but then the result is wrong.
Does anybody can give me an advise about what to do? Actually this should work with Web Services, shouldn't it?
I'd appreciate your help.
Pierre
  • Hello,
    Maybe the unfiltered result is in the cache of the browser.
    Try to clear it.
    Also check if it works with onaftergetrecord trigger.
    After the current record is retrieved from the table.
    OnAfterGetRecord Trigger
    When a record has been retrieved but not yet displayed.
    regards
  • Hello Thomas,
    thank you for your answer.  I don't use the Web Client. I want to use the page as Web Service. I check the Web Service via .NET Web Service Studio.
    I attached a xml file where you can see the result.
    I already tried the option with OnAfterGetRecord without success.
    8512.response_example.xml
    <?xml version="1.0" encoding="utf-16"?>
    <Soap:Envelope xmlns:Soap="http://schemas.xmlsoap.org/soap/envelope/">
      <Soap:Body>
        <Read_Result xmlns="urn:microsoft-dynamics-schemas/page/partner01tktsaisoncomplete">
          <Partner01TktSaisonComplete>
            <Key>28;rxUBAAJ7/zIAMAAxADUALwAxADY=10;33071215162;26;Partner01_Tkt_Spielpaarung33;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhw==10;33847184220;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwE=10;33847184230;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwI=10;33847184240;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwM=10;34212736980;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwQ=10;33847184260;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwU=10;33847184270;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwY=10;33847184280;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwc=10;33847184290;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwg=10;33847184300;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwk=10;33847184310;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhwo=10;33847184320;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhws=10;33847184330;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhww=10;33847184340;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhw0=10;33847184350;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhw4=10;33847184360;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhw8=10;33847184370;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxA=10;33847184380;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxE=10;33847184390;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxI=10;33847184400;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxM=10;33847184410;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxQ=10;33847184420;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxU=10;33847184430;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxY=10;33847184440;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxc=10;33847184450;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxg=10;33847184480;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxk=10;33847184490;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxo=10;33847184500;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxs=10;33847184510;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhxw=10;33847184520;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhx0=10;33847184530;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhx4=10;33847184540;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAh4I=10;33847184550;36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAh4M=10;33847184560;27;BMGTicketingTranslationList7;68;f8MAAH0TrxUBAAJ7/zIAMAAwADEALwAyADAAMAAyAAAAAAAAh3EXAAACe/9FAE4ARw==10;34335444340;68;f8MAAH0TrxUBAAJ7/zIAMAAwADEALwAyADAAMAAyAEEAAAAAAACHcRcAAAJ7/0UATgBH10;34335469640;68;f8MAAH0TrxUBAAJ7/zIAMAAwADIALwAyADAAMAAzAAAAAAAAh3EXAAACe/9FAE4ARw==10;34335504010;68;f8MAAH0TrxUBAAJ7/zIAMAAwADIALwAyADAAMAAzAEEAAAAAAACHcRcAAAJ7/0UATgBH10;34335525530;68;f8MAAH0TrxUBAAJ7/zIAMAAwADMALwAyADAAMAA0AAAAAAAAh3EXAAACe/9FAE4ARw==10;34335541890;68;f8MAAH0TrxUBAAJ7/zIAMAAwADMALwAyADAAMAA0AEEAAAAAAACHcRcAAAJ7/0UATgBH10;34335559990;60;f8MAAH0TrxUBAAJ7/zIAMAAxADYALwAxADcAAAAAAACHcRcAAAJ7/0UATgBH10;34330126530;</Key>
            <Code>2015/16</Code>
            <Beschreibung>Heimspiele 2015/16</Beschreibung>
            <Freigabe_Internet>false</Freigabe_Internet>
            <Gruppenkontringent>false</Gruppenkontringent>
            <Abo_Verwaltung_Web_aktiv>false</Abo_Verwaltung_Web_aktiv>
            <Partner01_Tkt_Spielpaarung>
                <Key>36;sBUBAAJ7/zIAMAAxADUALwAxADYAAAAAhw==10;33847184220;</Key>
                <Spielseriecode>2015/16</Spielseriecode>
                <Spieltag>0</Spieltag>
                <Stadioncode>03</Stadioncode>
                <Heim_Fremdspiel>Heimspiel</Heim_Fremdspiel>
                <Datum>0001-01-01</Datum>
                <Uhrzeit>15:30:00.0000000</Uhrzeit>
                <Heimmannschaft>Borussia</Heimmannschaft>
                <Gastmannschaft>Dauerkarte 2015/16</Gastmannschaft>
                <Veranstaltungsname>Dauerkarte 2015/16</Veranstaltungsname>
                <Dauerkarte_gültig>false</Dauerkarte_gültig>
                <Anzeige_Topevent>false</Anzeige_Topevent>
                <Heimfanblock_im_Web_ausblenden>false</Heimfanblock_im_Web_ausblenden>
                <Verkaufsart>kein_Verkauf</Verkaufsart>
                <Internet_Verkaufsstart_am>0001-01-01T00:00:00</Internet_Verkaufsstart_am>
                <Webverkauf_abgeschlossen>false</Webverkauf_abgeschlossen>
                <Warteliste_aktivieren>false</Warteliste_aktivieren>
              </Partner01_Tkt_Spielpaarung>
            <BMGTicketingTranslationList>
              <BMG_Ticketing_Translation_List>
                <Key>68;f8MAAH0TrxUBAAJ7/zIAMAAwADEALwAyADAAMAAyAAAAAAAAh3EXAAACe/9FAE4ARw==10;34335444340;</Key>
                <Record_ID>Spielserie 2017: 2001/2002</Record_ID>
                <Field_Number>6001</Field_Number>
                <Language_Code>ENG</Language_Code>
                <Description>11</Description>
              </BMG_Ticketing_Translation_List>
                <Key>68;f8MAAH0TrxUBAAJ7/zIAMAAwADEALwAyADAAMAAyAEEAAAAAAACHcRcAAAJ7/0UATgBH10;34335469640;</Key>
                <Record_ID>Spielserie 2017: 2001/2002A</Record_ID>
                <Description>22</Description>
                <Key>68;f8MAAH0TrxUBAAJ7/zIAMAAwADIALwAyADAAMAAzAAAAAAAAh3EXAAACe/9FAE4ARw==10;34335504010;</Key>
                <Record_ID>Spielserie 2017: 2002/2003</Record_ID>
                <Description>33</Description>
                <Key>68;f8MAAH0TrxUBAAJ7/zIAMAAwADIALwAyADAAMAAzAEEAAAAAAACHcRcAAAJ7/0UATgBH10;34335525530;</Key>
                <Record_ID>Spielserie 2017: 2002/2003A</Record_ID>
                <Description>44</Description>
                <Key>68;f8MAAH0TrxUBAAJ7/zIAMAAwADMALwAyADAAMAA0AAAAAAAAh3EXAAACe/9FAE4ARw==10;34335541890;</Key>
                <Record_ID>Spielserie 2017: 2003/2004</Record_ID>
                <Description>55</Description>
                <Key>68;f8MAAH0TrxUBAAJ7/zIAMAAwADMALwAyADAAMAA0AEEAAAAAAACHcRcAAAJ7/0UATgBH10;34335559990;</Key>
                <Record_ID>Spielserie 2017: 2003/2004A</Record_ID>
                <Description>66</Description>
                <Key>60;f8MAAH0TrxUBAAJ7/zIAMAAxADYALwAxADcAAAAAAACHcRcAAAJ7/0UATgBH10;34330126530;</Key>
                <Record_ID>Spielserie 2017: 2016/17</Record_ID>
                <Description>Test Test</Description>
            </BMGTicketingTranslationList>
          </Partner01TktSaisonComplete>
        </Read_Result>
      </Soap:Body>
    </Soap:Envelope>
Related
Recommended
