Amount In Words
Original code from Jonathan Archer https://community.dynamics.com/nav/b/moxie4nav/archive/2014/12/08/numbers-to-words
For usage run (sample):
InitTextVariables;
AmountInWords := NumberInWords(123456.78,'Cedis','Pesewas'); Message(AmountInWords);
NumberInWords(number : Decimal;CurrencyName : Text[30];DenomName : Text[30]) : Text[300]
WholePart := ROUND(ABS(number),1,'<');
DecimalPart := ABS((ABS(number) - WholePart)*100);
WholeInWords := NumberToWords(WholePart,CurrencyName);
IF DecimalPart <> 0 THEN BEGIN
  DecimalInWords := NumberToWords(DecimalPart,DenomName);
  WholeInWords := WholeInWords + ' and ' + DecimalInWords;
END;
AmountInWords := '****' + WholeInWords + ' Only';
EXIT (AmountInWords);
// local variables NumberInWords
Parameters
Var    Name                  DataType    Subtype    Length
No    number               Decimal
No    CurrencyName    Text                               30
No    DenomName      Text                               30
Return Value
Return Type     Length
Text                  300
NumberToWords(number : Decimal;appendScale : Text[30]) : Text[300]
numString := '';
IF number < 100 THEN
  IF number < 20 THEN BEGIN
    IF number <> 0 THEN numString := OnesText[number];
  END ELSE BEGIN
    numString := TensText[number DIV 10];
    IF (number MOD 10) > 0 THEN
      numString := numString + ' ' + OnesText[number MOD 10];
  END
ELSE BEGIN
  pow := 0;
  powStr := '';
  IF number < 1000 THEN BEGIN // number is between 100 and 1000
    pow := 100;
    powStr := ThousText[1];
  END ELSE BEGIN // find the scale of the number
    log := ROUND(STRLEN(FORMAT(number DIV 1000))/3,1,'>');
    pow := POWER(1000, log);
    powStr := ThousText[log + 1];
  END;
  numString := NumberToWords(number DIV pow, powStr) + ' ' + NumberToWords(number MOD pow,'');
END;
EXIT(DELCHR(numString,'<>',' ') + ' ' + appendScale);
// local variables NumberToWords
Parameters
No    number            Decimal
No    appendScale    Text                               30
Return Value
Return Type     Length
Text                  300
Variables
numString       Text                              300
pow                 Integer
powStr            Text                               50
log                   Integer
//Global Variables
// OnesText	Text	90 | Dim:20
// TensText	Text	90 | Dim:10
// ThousText	Text	90 | Dim:5
Set Dimension on the Property Page For The Global Variable
OnesText                 Text                              90
TensText                  Text                              90
ThousText               Text                              30
AmountInWords    Text                               300
WholeInWords       Text                               300
DecimalInWords    Text                               300
WholePart              Integer
DecimalPart            Integer
InitTextVariable()
OnesText[1] := 'One';
OnesText[2] := 'Two';
OnesText[3] := 'Three';
OnesText[4] := 'Four';
OnesText[5] := 'Five';
OnesText[6]:= 'Six';
OnesText[7] := 'Seven';
OnesText[8]:= 'Eight';
OnesText[9] := 'Nine';
OnesText[10] := 'Ten';
OnesText[11] := 'Eleven';
OnesText[12] := 'Twelve';
OnesText[13] := 'Thirteen';
OnesText[14] := 'Fourteen';
OnesText[15] := 'Fifteen';
OnesText[16] := 'Sixteen';
OnesText[17] := 'Seventeen';
OnesText[18] := 'Eighteen';
OnesText[19] := 'Nineteen';
TensText[1] := '';
TensText[2] := 'Twenty';
TensText[3] := 'Thirty';
TensText[4] := 'Forty';
TensText[5] := 'Fifty';
TensText[6]:= 'Sixty';
TensText[7] := 'Seventy';
TensText[8]:= 'Eighty';
TensText[9] := 'Ninety';
ThousText[1] := 'Hundred';
ThousText[2] := 'Thousand';
ThousText[3] := 'Million';
ThousText[4] := 'Billion';
ThousText[5] := 'Trillion';
Related
Recommended
