Microsoft Dynamics NAV flow fields
Good day all
I wrote some sql script to monitor overdue customer and their amounts outstanding. However I am unable to detect the correct Amount / Amount LCY value. I am querying the
[Detailed Cust_ Ledg_ Entry] table  as the main source and also [Cust_ Ledger Entry] table. how can I work around this issue to get the correct value as on NAV. below is a screenshot of the values and flow field in NAV as well as my SQL script (which do not display the correct value)
b.[Posting Date], --generally the posting date will be the same as the document date or after the document date
a.[Document Date],
a.[Due Date],
a.[Closed at Date],
b.[Entry Type],
CAST(c.[Blocked] AS NVARCHAR(5)) AS [Blocked],
CAST(b.[Document Type] AS NVARCHAR(10)) AS [Document Type],
CAST(b.[Customer No_] AS NVARCHAR(20)) AS [Customer No_],
--CAST(a.[Sell-to Customer No_] AS NVARCHAR(20)) AS [Sell-to Customer No_],
CAST(c.[Name] AS NVARCHAR(60)) [Customer Name],
CAST(b.[Document No_] AS NVARCHAR(10)) AS [Document No_],
CAST(a.[Description] AS NVARCHAR(50)) AS [Description],
CAST(b.[Source Code] AS NVARCHAR(10)) AS [Source Code],
CAST(b.[Currency Code] AS NVARCHAR(10))[Currency Code],
CAST(c.[Salesperson Code] AS NVARCHAR(10)) AS [Salesperson Code],
CAST(c.[Country_Region Code] AS NVARCHAR(10)) AS [Country_Region],
CAST(c.[Responsibility Center] AS NVARCHAR(10)) AS [Responsibility Center],
CAST(c.[Payment Terms Code] AS NVARCHAR(10)) AS [Payment Terms Code],
CAST(a.[Open] AS NVARCHAR(5)) AS [Open],
CAST(c.[Liquor License No_] AS [nvarchar](50)) AS [Liquor License No_],
c.[Suspension Period],
d.Name as [Country Name],
b.[Cust_ Ledger Entry No_],
c.[Credit Limit Annex No_],
sum(a.[Sales (LCY)]) as [Sales (LCY)],
sum(a.[Profit (LCY)])AS [Profit (LCY)],
sum(b.[Amount])AS [Amount],
sum(b.[Amount (LCY)])AS [Amount (LCY)], --LCY measure are financial amount in Local Currency
sum(b.[Debit Amount])AS [Debit Amount],
sum(b.[Credit Amount])AS [Credit Amount],
sum(b.[Debit Amount (LCY)])AS [Debit Amount (LCY)],
sum(b.[Credit Amount (LCY)] ) AS [Credit Amount (LCY)],
c.[Credit Limit (FCY)] AS [Credit Limit (FCY)],
c.[Credit Limit (LCY)] AS [Credit Limit (LCY)]
FROM [Spier Live$Detailed Cust_ Ledg_ Entry] b
LEFT JOIN [Spier Live$Customer] c
ON b.[Customer No_] = c.[No_]
LEFT JOIN [dbo].[Spier Live$Cust_ Ledger Entry] a
ON a.[Entry No_] = b.[Cust_ Ledger Entry No_]
LEFT JOIN [dbo].[Spier Live$Country_Region] d
ON c.[Country_Region Code] = d.[Code]
WHERE b.[Document No_] <> '0'
AND b.[Customer No_] NOT LIKE ('%ZZ%') --exclude sample customers
AND b.[Document No_] in ('117296','118830')
AND b.[Document Type] = '2'
GROUP BY b.[Posting Date], a.[Document Date], b.[Customer No_],
b.[Document Type],b.[Document No_], a.[Description], c.[Salesperson Code],
b.[Currency Code], b.[Source Code],a.[Open], a.[Due Date],c.[Blocked],
a.[Closed at Date],c.[Country_Region Code],c.[Responsibility Center],
c.[Name],c.[Payment Terms Code], b.[Entry Type], d.[Name], b.[Cust_ Ledger Entry No_],
[Credit Limit (FCY)],c.[Credit Limit (LCY)],c.[Credit Limit Annex No_],c.[Suspension Period],c.[Liquor License No_]
  • Hello, here you have a simple example which shows the Balance and Overdue Amounts.
    SELECT [CRONUS AG$Customer].No_, [CRONUS AG$Customer].Name, SUM([CRONUS AG$Detailed Cust_ Ledg_ Entry].[Amount (LCY)]) AS [Amount(LCY)], sum(case when [CRONUS AG$Cust_ Ledger Entry].[Due Date]<getdate() then [CRONUS AG$Detailed Cust_ Ledg_ Entry].[Amount (LCY)] else 0 end) as [OverDueAmount(LCY)]
    FROM     [CRONUS AG$Cust_ Ledger Entry] INNER JOIN
                      [CRONUS AG$Detailed Cust_ Ledg_ Entry] ON [CRONUS AG$Cust_ Ledger Entry].[Entry No_] = [CRONUS AG$Detailed Cust_ Ledg_ Entry].[Cust_ Ledger Entry No_] INNER JOIN
                      [CRONUS AG$Customer] ON [CRONUS AG$Cust_ Ledger Entry].[Customer No_] = [CRONUS AG$Customer].No_
    GROUP BY [CRONUS AG$Customer].No_, [CRONUS AG$Customer].Name
    HAVING ([CRONUS AG$Customer].No_ = '20000')
    Hope it helps you. . .
