Dynamics Nav Logic Programming
I want to ask a simple question about the Nav logic programming .
In CodeUnit (23) : Item Jnl.-Post Batch ,The standard use a record variable to copy rec and after the code processing ,it assign ItelJnlLine to Rec.
My questions are :
Why the system use this logic ?Why don't use directly Rec?
What the difference between a simple assign and ToRecord.Copy(FromRecord)?
Thank you.
