Display field from one table to another
Hi Friends,
I am new to NAV and I was hoping someone can teach me how to fish. The first challenge I have is I need to display the payment method code on the customer ledger entry table and ultimately on the customer ledger entry page. I was able to locate the customer ledger entry table on object designer and while creating a new field, I can't seem to find a field name called Payment Method Code. Any information you provide will help me tremendously in this initial learning stage.
Phil
  • If a field is not available in a table then you have to create it by adding Field No. , Field Name and Data Type.
    To include the field in page, open the page and On the View menu, click Field Menu. Select the field which you want to display.
    For more detailed steps : msdn.microsoft.com/.../dd338968.aspx
Related
