NAV 2016: How to read from a local client stream
Dear all,
I'm working on an interface to an electronic scale. I'm communicating with the scale via an online stream to a IP address and port no.
I was planning to the tcpClient and tcpListener dotnet functions to read and write to the stream. So far so good.
The problem that appears is that NAV is running this on the server, while the IP/port is only available from the client, as the scale is attached via the local USB port. So the communication needs to happen locally on the client.
Do you know if this is possible?
Related
Recommended
