Show and hide fields on a list page (On After get current Rec)?!!!
I want to hide a field (In a list page) after I get the current Rec.
I did the following:
1.Define a globe variable "IsVisible" and set its "IncludeInDataSet" property be "yes".
2. Set the property visible of the control in the page be "IsVisible"
3. create a function SetVisible (var visible : Boolean) to set the value of the variable "IsVisible"
etc, etc,..
My only problem is that this hide function works only (On open page & Init)!! But if you try to use it on other placsses like (On after get rec) IT WONOT WORK :(
Any Idea???
Parents
No Data
Reply
  • Ps: When I say hide a field I mean a text field not a column from the list page.
    I took a look at Microsoft support pages and I found this:
    This means there is no other way to control the visibility for each record after we retrieve it :( ?
Children
Related
Recommended
