RecRef.OPEN(27);FldRef := RecRef.FIELD(1); // Item."No."FldRef.SETRANGE('70000');RecRef.FIND('-');FldRef := RecRef.FIELD(3); // Item.Description;FldRef.VALUE('My own description');RecRef.MODIFY;
RecRef.OPEN(27);FldRef := RecRef.FIELD(1); // Item."No."FldRef.SETRANGE('70000');RecRef.FIND('-');FOR i := 1 TO RecRef.FIELDCOUNT DO BEGIN FldRef := RecRef.FIELDINDEX(i); CASE FldRef.NAME OF // Or you can use a case on FldRef.NUMBER 'Description': MESSAGE('%1 is %2.',FldRef.CAPTION,FldRef.VALUE); // Or do some changes 'Unit Cost': MESSAGE('%1 is %2.',FldRef.CAPTION,FldRef.VALUE); END;END;
recreffunc(database::item,item.getposition); // Call functionrecreffunc(tableno : integer, tableposition : text 30);begin RecordRef.OPEN(tableno); RecordRef.SETPOSITION(tableposition);end
hi
i want to write data from table to text file when ever the record is inserted in table...
is there any commend to get Table ID in to an variable
