Inserting an ExcelSheet
Hi there,
I want to export a Report (e.g. Report 4 Detail Trial Balance)directly to Excel.
A new Excel Sheet is inserted BEFORE existing Sheets - it should however be inserted AFTERwards to keep the output in the same order as it is displayed on the report itself.
My Questions:
1. How can I manage this[?]
2. Can I use any MOVE-instruction like this:
XlWorkSheet.Move([VARIANT Before][, VARIANT After])
I haven't found out yet how it works...
Thanks in advance for your help.
Juergen
  • Hi,
    first, it would be better, if questions are posted in the develeper forum.
    This is from Excel - helpfile:
    ActiveWorkbook.Sheets.Add Before:=Worksheets(Worksheets.Count)
    In Navision this should do the job:
    x := xlSheets.Count;
    // x = number of last sheet in workbook
    xlSheets.Add(,x);
    // add after last sheet
    Hope this helps
    bye
    Andre
  • Hi Andre,
    I tried to so with this source:
    NoOfSheets := XlWorkBook.Worksheets.Count;
    MESSAGE ('%1', NoOfSheets); //displays the correct number (1)of the last sheet
    XlWorkSheet := XlWorkBook.Worksheets.Add(NoOfSheets);
    //I tried these instructions. both of them return a runtime-error like this:
    ... the ADD-Method of the sheet object dould not be executed.
    regards
    Juergen
  • Hi Juergen,
    sorry for answering late.
    I had a day off yesterday.
    I must confess I didn't tested my solution for
    this problem.
    I'll try to check it today and then I come back
    with a posting.
    bye
    Andre
  • Hi Juergen,
    unfortunately I didn't found a way to solve this problem [V].
    I've got always error messages from Excel.
    If you search Google Groups for 'Excel sheets.add' you will see
    many people with the same problem.
    Sorry
    Andre
  • Hy J├╝rgen
    My reports exporting data to excel always ;) need a Total sheet at the end.
    First you have to create the "Total-Sheet", than it's easy to create a new sheet at second-Last Position like this:
    Sheet:= Excel.Sheets.Item('Total');
    Sheet:= Excel.Sheets.Add(Sheet);
    Sheet.Name := Strsubstno(.....
    it's not a solution, but a way to avoid problems ;)
    Bye('Stefan')
  • hi,
    use this, it works
    create(xl);
    xl.visible:=true;
    xlworkbook:=xl.workbooks.add;
    xlsheet := xl.ActiveWorkbook.Sheets.Item(xl.ActiveWorkbook.Sheets.Count);
    xlsheet.Activate;
    xlsheet.name:='Detail Trail Balance';
Related
Recommended
