error message...
Helo!
This probably isn't the topic for this forum but i know that programmers lots of times know more that system administrators [:D]
Anyway the message i got from Navision Attain 3.10 was :
"Internal Error 2 in Module 10"
"If you need help call you distributer"
"ok"
This damn message was poping out everytime i closed Navision. And when i reopened it i had to set the database and company again. Finally i got tired of it and reinstalled the whole thing. Now it works but i'm still wondering what that error message ment. If anyone has encountered this error and knows what it is about then please reply to this topic...
thnx
lp prosen
  • A brief overview of Internal Errors in Modules 2 - 18:
    5 1 #Err_BT_AllReadyExist (Module_BT,Err_Fatal(1))
    5 2 #Err_BT_NotFound (Module_BT,Err_Fatal(2))
    5 444 #Err_BT_Test (Module_BT,Err_Fatal(444))
    6 6 #Err_OM_AllocTooBig (Module_OM,6)
    6 7 #Err_OM_ReAllocTooBig (Module_OM,7)
    9 2 #Err_UT_UnknownType (Module_UT, 2 )
    9 3 #Err_UT_ModuleNotRegistered (Module_UT,Err_Fatal(3))
    9 4 #Err_UT_BadModuleNr (Module_UT,Err_Fatal(4))
    10 1 #Err_Tab_TabTooSmall (Module_Tab,Err_Fatal(1))
    10 2 #Err_Tab_PlacTooBig (Module_Tab,Err_Fatal(2))
    10 3 #Err_Tab_NoMemory (Module_Tab,Err_Fatal(3))
    10 10 #Err_Tab_FixedWidthInvalid (Module_Tab, 10)
    10 11 #Err_Tab_NoOfElementsInvalid (Module_Tab, 11)
    10 12 #Err_Tab_FixedVarOverlap (Module_Tab, 12)
    10 13 #Err_Tab_VarPtrError (Module_Tab, 13)
    11 1 #Err_Att_AttTooSmall (Module_Att,1)
    11 2 #Err_Att_DestMaxOvfl (Module_Att,2)
    11 100 #Err_Att_Undefined (Module_Att,Err_Allowable(100))
    12 1 #Err_STab_TryToModifyRO (Module_STab,Err_Fatal(1))
    12 1 #Err_XTab_TryToModifyRO (Module_STab,Err_Fatal(1))
    12 2 #Err_STab_UnknownAttr (Module_STab,Err_Fatal(2))
    12 2 #Err_XTab_UnknownAttr (Module_STab,Err_Fatal(2))
    12 3 #Err_STab_STabToLarge (Module_STab,Err_Fatal(3))
    12 3 #Err_XTab_XTabToLarge (Module_STab,Err_Fatal(3))
    12 4 #Err_STab_RootExpected (Module_STab,Err_Fatal(4))
    12 4 #Err_XTab_RootExpected (Module_STab,Err_Fatal(4))
    15 1 #Err_Stack_Full (Module_Stack,1)
    15 2 #Err_Stack_Overwritten (Module_Stack,Err_Fatal(2))
    17 1001 #Err_File_InvalidAttribute (Module_File,Err_Fatal(1001))
    17 1006 #Err_File_NameTooLong (Module_File, 1006 )
    17 1008 #Err_File_InvOptWhenNoBuffer (Module_File,Err_Fatal(1008))
    17 1009 #Err_File_ReadNotExact (Module_File, 1009 )
    17 1010 #Err_File_LineTooLong (Module_File,Err_Fatal(1010))
    17 1012 #Err_File_BufferTooBig (Module_File,Err_Fatal(1012))
    17 1014 #Err_File_SeekOnCharDevice (Module_File, 1014 )
    17 1015 #Err_File_Changed (Module_File, 1015 )
    17 1016 #Err_File_CopyToSameFile (Module_File, 1016 )
    17 1017 #Err_File_CopyCannotRename (Module_File, 1017 )
    17 1018 #Err_File_ZipBadFormat (Module_File, 1018 )
    17 2100 #Err_File_TooBig (Module_File,2100L)
    18 1 #Err_BCMIA_Overflow (Module_BCMIA,1)
    18 2 #Err_BCMIA_Illigal (Module_BCMIA,2)
Related
Recommended
