Date calculation Issue
Dear Sir
I create a page where users select two dates, now we want to display the gap between two days.
For example:
Appointment Date: "user select the calendar"   -Input
Re leaving Date :" User Select the calendar- Input
Working Date: " Re leaving Date-Appointment Date"-should be populate  automatic.
How and where we have to write the code??????
Please explain details.
Regards
Nabin
  • simply calculate enddate-startdate. you get the number of days as result.
  • In reply to archer, MVP:
    Write code in OnValidate() trigger of the field in page. If these are table fields, you may write code OnValidate() trigger of fields in the table.
    For, Working Date = " Re leaving Date-Appointment Date", here goes the code,
    Re leaving Date - OnValidate()
    IF ("Re leaving Date" <> 0D) AND ("Appointment Date" <> 0D) THEN BEGIN
      IF ("Re leaving Date" > "Appointment Date") THEN
        "Working Date" := ("Re leaving Date" - "Appointment Date")
      ELSE
        ERROR('Re leaving Date must be greater than Appointment Date');
    END;
    Appointment Date - OnValidate()
      ELSE
    END;
    Note that "Working Date" is not a date, it must be an integer for the above code to work. If you need your result as a date then some more code is required.
  • In reply to Ishwar Sharma:
    Hi Ishwar
    It is working bro....
     thank you.......From the bottom of my heart .
  • In reply to Nabin Sinha:
    Hi Nabin, You're welcome. :)
    Please verify the solution and don't forget to verify solutions in future as well whenever you get the solution to your issues in dynamicsuser.net
    Problem Solved.
    Thanks Once again.
    Regards
    Nabin Kumar Sinha
Related
