Batch Recovery Window
Processing a check batch - received messages re: distribution errors, total amount applied incorrect, etc. etc. Two checks did not post correctly. Rest of check batch posted fine.
Help menu says the Batch Recovery should change from Computer Check Posting Error to Edit Required but it does not.
Attempted to process Batch Recovery for the Computer Check Posting Error and I receive message "Data entry errors exist in batch xyz.  Use the Batch Recovery window to process this batch.
Seems like a never ending circular problem.
Related
Recommended
