GP 2015 Workflow Setup
Hello:
Upon trying to send a test e-mail from the Workflow Setup window of GP 2015 (14.00.0619), I get the following error:
An error occurred in the Microsoft .NET Framework while trying to load assembly id 65564.  The server may be running out of resources, or the assembly may not be trusted with PERMISSION_SET = EXTERNAL_
Any ideas?
I have tried reviewing the information in the link below, but I have the following questions:
On the first method discussed on that page, in the link, I cannot tell which database to run the script against.  I hope that it's not the master database, because I'm nervous about making changes to the master database.  Anyway, which database do I run the script against?
Likewise, the second method suggests running a script against the master database.  I'm not so sure that I want to do that.
Is it safe to make such changes to the master database?
http://www.msqlserver.net/2015/05/the-server-may-be-running-out-of.html
Thanks!
John
Related
Recommended
