Error Management Reporter - Bad or missing data was encountered while loading the report and its building blocks. Report generation has been cancelled
hi,
i have a problem with CU7 management reporter , i update the program and show this message in the report generation.
"Bad or missing data was encountered while loading the report and its building blocks. Report generation has been cancelled."
anybody has seen this message? Please Help
i tried:
1.- Restart services.
2.- Verify security
3.- Check building blocks
4.- Check row, columns, report definition
5.- Create a new report definition, row, column and building block
in the log show this:
Microsoft.Dynamics.Performance.Reporting.DataProvider.Service.DirectLinkException: The operation could not be completed because the specified credentials are not valid. ---> Microsoft.Dynamics.Performance.DataProvider.GeneralLedger.GLConnectionAuthorizationException: The user ID and password are not a valid login.
   at Microsoft.Dynamics.Performance.DataProvider.GeneralLedger.GP.Data.DataConnector.CreateConnectionUsingGPCredentials(String dataSourceName, String databaseName, String userName, String password)
   at Microsoft.Dynamics.Performance.DataProvider.GeneralLedger.GP.Data.DataConnector.CreateConnection()
   at Microsoft.Dynamics.Performance.DataProvider.GeneralLedger.GP.Data.DataConnector.OpenConnection()
   at Microsoft.Dynamics.Performance.DataProvider.GeneralLedger.GP.Data.DataConnector.EnsureDatabaseAccess(String dynamicsDatabase, String entityDatabase)
   at Microsoft.Dynamics.Performance.DataProvider.GeneralLedger.GP.GLProvider.HandleConnect(EntitySettingCollection settings, CredentialCollection credentials)
   at Microsoft.Dynamics.Performance.DataProvider.Core.SourceSystemConnection.Open()
   at Microsoft.Dynamics.Performance.DataProvider.Core.SourceSystem.Connect(EntitySettingCollection settings, CredentialCollection credentials)
   at Microsoft.Dynamics.Performance.Reporting.DataProvider.Server.DirectLinkConnectionManager.CreateSourceSystemConnection(Guid providerTypeId, EntitySettingCollection settings, StoredCredential credential)
   --- End of inner exception stack trace ---
Server stack trace:
   at Microsoft.Dynamics.Performance.Reporting.DataProvider.Server.DirectLinkConnectionManager.CreateSourceSystemConnection(Guid entityId, StoredCredential credential)
   at Microsoft.Dynamics.Performance.Reporting.DataProvider.Server.DirectLinkConnectionManager.CreateSourceSystemConnection(DataServiceConnection connection)
   at System.Lazy`1.CreateValue()
Exception rethrown at [0]:
   at System.Lazy`1.LazyInitValue()
   at Microsoft.Dynamics.Performance.DataProvider.Core.AutoExpiringDisposableCache`2.AutoExpiringDisposableCacheItem`2.GetItem(Boolean acquireOwnership)
   at Microsoft.Dynamics.Performance.DataProvider.Core.AutoExpiringDisposableCache`2.GetOrAdd(TKey key, Func`2 createCacheItemValue, Boolean acquireOwnership)
   at Microsoft.Dynamics.Performance.Reporting.DataProvider.Server.DirectLinkConnectionManager.UsingConnection[TResult](DataServiceConnection connection, Func`2 executor)
   at Microsoft.Dynamics.Performance.Reporting.DataProvider.Server.DirectLinkService.<>c__DisplayClassb.<Connect>b__9()
   at Microsoft.Dynamics.Performance.Reporting.Security.Service.SecureServiceBase.SecureExecuteInternal[TResult](Func`1 hasPermission, Func`1 executor)
   at Microsoft.Dynamics.Performance.Reporting.Common.Service.ServiceBase.BaseExecute[TResult](Func`1 executor)
 Component: Microsoft.Dynamics.Performance.Reporting.DataProvider.Server.DirectLinkService
 User: ALIBAL\Administrator
System.ServiceModel.FaultException`1[Microsoft.Dynamics.Performance.Reporting.Common.Service.ServiceFault]: Invalid URI: The hostname could not be parsed. (Fault Detail is equal to Microsoft.Dynamics.Performance.Reporting.Common.Service.ServiceFault).
Related
Recommended
