Item Allocation
I have an item that had been allocated and after running inventory reconcile, it proofed futile.
Is there any idea or way I can look at regarding the item.
  • Not sure if you have already got to know about this. Here are my thoughts:
    1. If you are using Service Call management, any spares that are used on a call would be marked as allocated and may probably not show up in the Qty Allocated list (till GP 2013 SP1).
    2. If you have any SO or invoice stuck while getting posted, the item would still be considered as allocated, but that stuck document would not show up in the Qty Allocated list.
    Hope these points help.
    Vaidy
  • In reply to Vaidhyanathan Mohan:
    Thanks Vaidy for your input I managed to clear it through the reconcile at last.
Related
Recommended
