EConnect RMA Serial Line: Error
I am in the process of creating a custom interface to receive items on an RMA and am using eConnect to do this. I am encountering an error that specifies the Return_Record_Type is missing. In the XML document it is clearly there. I am attaching the error and xml document along with the code that is setting it. I am using C# to perform this.
C# Code:
//RMA Serial Item ( GP Table: SVC05255)
detailcount = 0;
taFSRMALineSerial_ItemsTaFSRMALineSerial serialitem = new taFSRMALineSerial_ItemsTaFSRMALineSerial();
serialitem.Return_Record_Type = 1;
serialitem.RETDOCID = rmaheader.RETDOCID;
serialitem.CUSTNMBR = rmaheader.CUSTNMBR;
serialitem.LNSEQNBR = 100;
serialitem.QTYTYPE = 1;
serialitem.ITEMNMBR = "VX510 DC";
serialitem.SERLNMBR = "2-2-2-2";
serialitem.SERLTQTY = 1;
serialitem.SLTSQNUM = detailcount + 1;
serialitem.ADRSCODE = "PRIMARY";
serialitem.LOCNCODE = "RETURN";
serialitem.SVC_Original_Serial = 1;
serialitem.SVC_Original_SerialSpecified = true;
serialitem.UpdateIfExists = 1;
serialitems[detailcount] = serialitem;
eConnect Error:
Procedure or function 'taFSRMALineSerial' expects parameter '@I_vReturn_Record_Type', which was not supplied.
XMLDocument:
<?xml version="1.0" ?>
- <eConnect xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
- <FSRMAType>
  <eConnectProcessInfo xsi:nil="true" />
  <taRequesterTrxDisabler_Items xsi:nil="true" />
- <taFSRMALineSerial_Items>
- <taFSRMALineSerial>
  <Return_Record_Type>1</Return_Record_Type>
  <RETDOCID>RMA0KFP000002</RETDOCID>
  <CUSTNMBR>BBTFINANC027494</CUSTNMBR>
  <ADRSCODE>PRIMARY</ADRSCODE>
  <LNSEQNBR>100</LNSEQNBR>
  <ITEMNMBR>VX510 DC</ITEMNMBR>
  <SERLNMBR>2-2-2-2</SERLNMBR>
  <LOCNCODE>RETURN</LOCNCODE>
  <SLTSQNUM>1</SLTSQNUM>
  <SVC_Original_Serial>1</SVC_Original_Serial>
  </taFSRMALineSerial>
  <taFSRMALineSerial xsi:nil="true" />
  </taFSRMALineSerial_Items>
- <taFSRMALine_Items>
- <taFSRMALine>
  <RETTYPE>RP</RETTYPE>
  <RETSTAT>20</RETSTAT>
  <ITEMDESC>0126011 - P/N M251-060-36-NAA VX510 DC 6-meg</ITEMDESC>
  <RETORIG>1</RETORIG>
  <LNITMSEQ>100</LNITMSEQ>
  <QUANTITY>1</QUANTITY>
  <UOFM>EACH</UOFM>
  <CUSTOWN>1</CUSTOWN>
  </taFSRMALine>
  <taFSRMALine xsi:nil="true" />
  </taFSRMALine_Items>
- <taFSRMAMaster>
  <RETSTAT>10</RETSTAT>
  <CUSTNAME>BB&T Financial, FSB</CUSTNAME>
  <CONTACT>Attn.: BB&T Equipment Manager</CONTACT>
  <ADDRESS1>2713 Forest Hills Road</ADDRESS1>
  <CITY>Wilson</CITY>
  <STATE>NC</STATE>
  <ZIPCODE>27893</ZIPCODE>
  <Bill_To_Customer>BBTFINANC027494</Bill_To_Customer>
  </taFSRMAMaster>
  </FSRMAType>
  </eConnect>
  • I found the problem...It helps when you have the line count correct when creating the objects...and a second pair of eyes come in handy as well.
    taFSRMALineSerial_ItemsTaFSRMALineSerial[] serialitems = new taFSRMALineSerial_ItemsTaFSRMALineSerial[LineCount];
    taFSRMALine_ItemsTaFSRMALine[] lineitems = new taFSRMALine_ItemsTaFSRMALine[LineCount];
Related
Recommended
