Track back from "payroll calculate checks" to PA Timesheet & Payroll transaction GP 2010 & GP2013
I am using GP 2010, SP5 and US Payroll with below integrations. Need this in both GP2010 & GP2013
PA - Project Accounting, TS - Timesheet, SL - Subledger, GL - General Ledger, PR - Payroll
(A) 1st query
(1) PA TS integrated with Payroll, payroll integrated with vendor,
    PA TS integrated with Billing, and all post to/through SL & GL
(2) Post TS which would be available in PR batch
(3) Build Checks & Calculate checks (stop here)
Here is my customization need.
I need to fetch the Tax amounts, benefit amounts which are in below tables relating to
  the PR posted and TS posted tables. I need to track these tax & benefit amounts to
  the trx ids of PR & TS
   UPR10202 -- UPR_WORK_HDR -- Payroll Work Header
   UPR10205 -- UPR_WORK_Benefit -- Payroll Work Benefit
I could not get a link between these tables to PR & TS tables nor in SDK. Can anyone help me to
 the column that links  Calculate check & PR & TS posted tables
(A) 2nd query
I also would like to get a similar link after Print Checks process completed between
after posted print checks, PR trx no. & TS trx no. (or such key)
After print checks the data would be in other tables & not in "UPR Work tables".
Your early help would be much appreciated.
