Custom Menu Issue
I'm porting over a GP 6 to GP 2015 and trying to move over the custom menu code in the startup procedure.  It compiles but does not run.  Even when I run it with a debug it shows nothing.
Any suggestions?
local integer Seq,Status,LoadMode;
local integer l_result;
Seq = 0;
Status = AddCommandToMenu(DYNAMICS,
resourceid(form Command_Sales),
resourceid(command CL_Sales_Cards of form Command_Sales),
     Seq,
     Runtime_GetCurrentProductID(),
     resourceid(command cmdSeparator),
     true,
     LoadMode);
if Status <> OKAY then
error "Could not add command Custom Menu";
end if;
if Trigger_RegisterProcedure(script CreateDefaultMenuStructure, TRIGGER_AFTER_ORIGINAL, script Style_Eyes_Open_Menu) <> SY_NOERR then
warning "Procedure trigger registration failed.";
end if;
if Trigger_RegisterProcedure(script 'OpenCommandForms', TRIGGER_AFTER_ORIGINAL, script Style_Eyes_Open_Menu) <> SY_NOERR then
warning "OpenCommandForms procedure trigger registration failed.";
end if;
  • Hey dcervelli  please follow following link same issue i have face before some time...
    https://community.dynamics.com/gp/f/32/t/174065
    Hope this is helpful to you !!Smile
    Thanks & Regards,
    GOVIND DEVDA
Related
Recommended
