Plugin Debug error -Unable to parse the OrganizationServiceFault
I am trying to debug a plugin using plugin profile.  However i am getting below issue when i try to provide the profiled ErrorDetails.txt file. (copied the full error output below)
We are using CRM 2015 On-premise.
Tried the solution provided in this URL
however this did not solve the issue and still getting the same problem.
Any questions to help will be greatly appreciated.
Error Details
Unhandled Exception: System.ArgumentException: Unable to parse the OrganizationServiceFault.
Parameter name: serializedReport
   at PluginProfiler.Library.ProfilerUtility.ExtractReport(String serializedReport)
   at PluginProfiler.Library.ProfilerUtility.DeserializeProfilerReport(String assemblyFilePath, String logFilePath, Boolean isCrmDataStream)
   at PluginProfiler.Library.ProfilerExecutionUtility.RetrieveReport(String logFilePath, Boolean isCrmDataStream)
   at Microsoft.Crm.Tools.PluginRegistration.CommonControls.Helper.ParseReportOrShowError(Window window, FileBrowserView profilePathControl, Boolean requireReportParse, ProfilerPluginReport& report)
Inner Exception: System.Runtime.Serialization.SerializationException: Error in line 1 position 279. Element 'schemas.datacontract.org/.../System.Collections.Generic:value' contains data from a type that maps to the name ':int'. The deserializer has no knowledge of any type that maps to this name. Consider using a DataContractResolver or add the type corresponding to 'int' to the list of known types - for example, by using the KnownTypeAttribute attribute or by adding it to the list of known types passed to DataContractSerializer.
   at System.Runtime.Serialization.XmlObjectSerializerReadContext.InternalDeserialize(XmlReaderDelegator reader, String name, String ns, Type declaredType, DataContract& dataContract)
   at System.Runtime.Serialization.XmlObjectSerializerReadContext.InternalDeserialize(XmlReaderDelegator xmlReader, Int32 id, RuntimeTypeHandle declaredTypeHandle, String name, String ns)
   at ReadKeyValuePairOfstringanyTypeFromXml(XmlReaderDelegator , XmlObjectSerializerReadContext , XmlDictionaryString[] , XmlDictionaryString[] )
   at System.Runtime.Serialization.ClassDataContract.ReadXmlValue(XmlReaderDelegator xmlReader, XmlObjectSerializerReadContext context)
   at ReadErrorDetailCollectionFromXml(XmlReaderDelegator , XmlObjectSerializerReadContext , XmlDictionaryString , XmlDictionaryString , CollectionDataContract )
   at System.Runtime.Serialization.CollectionDataContract.ReadXmlValue(XmlReaderDelegator xmlReader, XmlObjectSerializerReadContext context)
   at ReadOrganizationServiceFaultFromXml(XmlReaderDelegator , XmlObjectSerializerReadContext , XmlDictionaryString[] , XmlDictionaryString[] )
   at System.Runtime.Serialization.XmlObjectSerializerReadContext.InternalDeserialize(XmlReaderDelegator xmlReader, Type declaredType, DataContract dataContract, String name, String ns)
   at System.Runtime.Serialization.DataContractSerializer.InternalReadObject(XmlReaderDelegator xmlReader, Boolean verifyObjectName, DataContractResolver dataContractResolver)
   at System.Runtime.Serialization.XmlObjectSerializer.ReadObjectHandleExceptions(XmlReaderDelegator reader, Boolean verifyObjectName, DataContractResolver dataContractResolver)
   at System.Runtime.Serialization.XmlObjectSerializer.ReadObject(XmlDictionaryReader reader)
   at PluginProfiler.Library.ProfilerUtility.ExtractReport(String serializedReport)l
Related
Recommended
