GroupWise to Office 365 migration software features
If you have been seeking to carry Novell GroupWise to Office 365 migration, the GroupWise to Office 365 migration tool by Shoviv Software would be the perfect choice for you. This tool has got compatibility with all the versions of GroupWise and those of Microsoft Outlook as well. It is an easy way to migrate all GroupWise emails to Office 365. It is compatible with all Windows Operating Systems, canceling any possibility of obstruction of Novell GroupWise to Office 365 migration.
Key features of Novell GroupWise to Office 365 Migration tool:
  • No limitation of size with regards to files in data conversion
  • Fast Novell GroupWise to Office 365 migration with safety
  • Migrates even archive data from Novell GroupWise to Office 365
  • Allows for saving the converted data into various formats after Novell GroupWise to Office365conversion, including PST, EML, and MSG
  • Migrate data from Novell GroupWise to Office 365 public folder and archive mailbox
  • All GroupWise mail clients supported – 5.5, 6.5, 6.0, 8.0, 7.0, 2012, 2014, 18.0
  • Supports all versions of Windows operating system
  • Supports all versions of Novell GroupWise
  • Lifetime free technical support for clients
  • User-friendly Graphical Interface prepared specially for beginners
  • Free consultant service to help for data migration
You would not feel abandoned if you are facing some problem with the task to Novell GroupWise to Office 365 migration. Once you have become our client, you will never have to wait to get your issues related to Novell GroupWise to Office 365 migration resolved. Our technical support team will be available 24*7 to assist you.
Free trial version:
The free trial version of this tool serves as a sample for the full version. It has got all the features of the upgraded version and you can use it till you decide that it fulfills all your needs related to Novell GroupWise to Office 365 migration. While the trial version allows to export of 25 items, there is no such limitation with the full version of this tool. We suggest that you use all the features of the trial version and then get the full version. Once you have used the full version, do not forget to update us regarding your experience with the tool.
  • To migrate a single mailbox from GroupWise to Office 365 with kernel
    There are three login modes which you can use to access the GroupWise mailbox –
    1. Default Mode
      It migrates the current working user in the Novell GroupWise.
    2. Login Mode
      In this, you will login to the Novell GroupWise using the account credentials.
    3. Command Line Mode
      The command line mode allows you to access the Novell GroupWise mailbox without opening or logging to the account.
    Here is the brief procedure of converting the Novell GroupWise mailbox to Office 365 –
    1. Start the software and choose your desired mode. In the present example, Login Mode is selected.
      In Login mode, you need to input the User ID, Password, and any of the Online Address, caching mailbox path, or remote mailbox path. Then click Next.
    2. The tool enlists the user mailboxes. You can select any item and get its preview. After selecting the mailboxes, click Export.
    3. Select the second option to ‘Save to Live Exchange/Office 365.’
    4. Choose Office 365 as the destination option.
    5. Input the User ID and Password of Office 365 account and click OK.
    6. Check the box to select the source mailbox, and then click the Mapping button.
    7. Choose the destination mailbox and click OK.
    8. In the Export Option window, you can use various filters to choose the data based on item type or a date range. At last, click Export.
    9. The tool starts the office 365 migration, and you can see the live status of migration.
    Adrian
Related
Recommended
