This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
FaultException `1 An item with the same key has already been added.
Hi everyone!
I am new in customizing the dynamics CRM 2011. I am importing data through sync function.
I created a c# solution that will retrieve data from a source database, then import it in CRM through the Create method.
The problem is, I encountered the error:
"An item with the same key has already been added."
The entity where I'm supposed to create a record is still empty. That is why I'm wondering where the error came from.
Any help will be highly appreciated.
Thank you so much!
Related
Recommended
