This discussion has been locked.
You can no longer post new replies to this discussion. Posts are automatically locked, when no new replies have been made for a long time. If you have a question you can start a new discussion.
Custom dialog window or another user interaction using JScript
Hello,
I am looking for directions how to find the best way to solve problem with plug in I am making.
Addon should work like this:
1. obtain information form user as input data for plug-in
2. run custom business logic
3. present output data back to the user
4. allow user to modify the data
5. based on this data create new record of Account entity.
I tried to create JScript using ExtJS framework to display custom dialog window inside web page. This solution works well
when accessed in web bowser, but is not working in Outlook client.
I am not sure if displaying custom dialog window is the best way to achieve the goal. Is there better way how to interact
with user using JScript? Or better way how to create custom window (like using window.open() method)?
Thanks for reply.
Related
Recommended
