Error due to LookupObjects javascript method in MSCRM 2013 online
We were using below code that works fine in MSCRM online 2011 online to show custom view in multi-selected lookup dialog page on click of Add Existing Records ribbon button in subgrid of associated entity.
function addExistingFromSubGridQuoteProducts(gridTypeCode, gridControl, shipmentID) {
      var entity = Xrm.Page.data.entity.getEntityName();
       var QuoteAttribute = Xrm.Page.getAttribute("new_quoteid");
       if (QuoteAttribute == null) {
           QuoteAttribute = Xrm.Page.getAttribute("new_quote");
       var Quote = QuoteAttribute.getValue();
       var Quoteid = "Unknown";
       if (Quote != null) {
           Quoteid = Quote[0].id;
       var filter =  "<filter type='and'>"
                   + "<condition attribute='new_quoteshipmentid' operator='null' />"
                   + "</filter>"
       var fxml = "<fetch version='1.0' output-format='xml-platform' mapping='logical' distinct='false'>"
         + "<entity name='quotedetail'>"
           + "<attribute name='productid' />"
           + "<attribute name='productdescription' />"
           + "<attribute name='priceperunit' />"
           + "<attribute name='quantity' />"
           + "<attribute name='extendedamount' />"
           + "<attribute name='quotedetailid' />"
           + "<order attribute='productid' descending='false' />"
           + filter
           + "<link-entity name='quote' from='quoteid' to='quoteid' alias='aa'>"
             + "<filter type='and'>"
               + "<condition attribute='quoteid' operator='eq' value='" + Quoteid + "' />"
             + "</filter>"
           + "</link-entity>"
         + "</entity>"
       + "</fetch>";
       addExistingFromSubGridCustom({
           entityName: entity,
           gridTypeCode: gridTypeCode,
           gridControl: gridControl,
           fetchXml: fxml,
           layoutXml: "<grid name='resultset' " +
                            "object='1' " +
                            "jump='productid' " +
                            "select='1' " +
                            "icon='1' " +
                            "preview='1'>" +
                        "<row name='result' " + "id='quotedetailid'>" +
                          "<cell name='productid' width='300' />" +
                          "<cell name='productdescription' width='300' />" +
                        "</row>" +
                      "</grid>"
function addExistingFromSubGridCustom(params) {
   viewId = "{00000000-0000-0000-0000-000000000001}";
   var customView = {
       fetchXml: params.fetchXml,
       layoutXml: params.layoutXml,
       name: "Filtered Lookup View",
       recordType: params.gridTypeCode,
       Type: 0
   var lookupItems = LookupObjects(null, "multi", params.gridTypeCode, 0, null, "", null, null, null, null, null, null, viewId, [customView]);
   if (lookupItems && lookupItems.items.length > 0) {
       for (var i = 0; i< lookupItems.items.length; i++){
           var lhsEntityId;
           var lhsSet;
           var relatedEntityId;
           var relatedEntitySet = "";
           var relationName = "";
           lhsEntityId = Xrm.Page.data.entity.getId();
           lhsSet = "new_quoteshipmentSet";
           relatedEntityId = lookupItems.itemsIdea.id;
           relatedEntitySet = "QuoteDetailSet";
           relationName = "new_quoteshipment_quotedetail";
           var done = XrmServiceToolkit.Rest.Associate(
                   lhsEntityId,
                   lhsSet,
                   relatedEntityId,
                   relatedEntitySet,
                   relationName,
                   function () {
                       var i = 0;
                   function (error) {
                       var i = 0;
                   false
       params.gridControl.refresh();
But after upgrade to MSCRM 2013, This code shows multi-selected lookup with custom view selected in viewpicker but throws following error:
“The requested record was not found or you do not have permissions to view.”
On click of show error logs in error window, following error detail was shown:
“savedquery With Id = 00000000-0000-0000-0000-000000000000 Does Not Exist.”
On debugging of above javascript code, I found that the error is thrown by following line of code:
could someone please help me in fixing of this error due to  LookupObjects javascript method in MSCRM 2013 online.
This is quite urgent to fix and Any help will be highly appreciable.
Related
Recommended
