Error on connecting CRM 2013 Outlook plugin to CRM 2013
Error from log:
11:00:39|   Info| Query all rows in msg service table
11:00:39|Verbose| Method exit: Microsoft.Crm.Application.Outlook.Config.OutlookCRMDatastoreInstaller.GetServiceIds
11:00:39|Verbose| Method exit: Microsoft.Crm.Application.Outlook.Config.OutlookCRMDatastoreInstaller.GetCrmStoreServiceId
11:00:39|Verbose| Method exit: Microsoft.Crm.Application.Outlook.Config.OutlookCRMDatastoreInstaller.DeleteV4CrmDatastore
11:00:39|Verbose| Method entry: Microsoft.Crm.Application.Outlook.Config.OutlookConfigurator.InitializeMapiStoreForFirstTime
11:02:04|  Error| Exception : An error has occurred. Try this action again. If the problem continues, check the Microsoft Dynamics CRM Community for solutions or contact your organization's Microsoft Dynamics CRM Administrator. Finally, you can contact Microsoft Support.    at Microsoft.Crm.Application.Outlook.Config.OutlookConfigurator.InitializeMapiStoreForFirstTime()
   at Microsoft.Crm.Application.Outlook.Config.OutlookConfigurator.Configure(IProgressEventHandler progressEventHandler)
   at Microsoft.Crm.Application.Outlook.Config.ConfigEngine.Configure(Object stateInfo)
11:02:04|  Error| Exception : Server was unable to process request.
On-premises version.
Windows server 2008R2 x64
Related
Recommended
