the finished quantity is wrong and the production order has been ended
hi,everybody,
I have found that the finished quantity in system(dynamics 365 F&O) is more than actually after end the production order .I want to know how to handle this  or adjust quantity and make inventory quantity and  cost correctly.
Thanks.
  • If it's different after ending the production order, you'd have to do an inventory movement journal or something to get the quantity adjusted.  There is no way to "unend" a production order after you've ended it.
    If you need to get the inventory back in stock for the subcomponents, you could try a negative production order or a negative bill of materials journal.  That might get things back where they should be and get rid of your extra inventory.  Test it in a test environment first, of course.
Related
Recommended
