Production Order Error when reporting as Finished
Trying to report as finished a production order and we get this error.
Cannot edit a record in Purchase orders (PurchTable). The record has never been selected.
Update has been cancelled.
Any ideas on how to fix this
  • might be database sync issue or  any select queires is not updating properly (record is not selected to update)
  • I think you are trying to post a production order which is having link with subcontracting purchase order.
    This may happen when the linkage between purchase and production order is break, because of seperate purchase order posting or updating the purchase order.
    You May try below options:
    1. Close the existing PO
    2. Clear the parameters which says post the PO when doing RAF from production parameters form.
    3. Clear the transactions from table which is stopping you from doing RAF...
Related
Recommended
