hi all ,
when i issue the store requsition it showing a warningstock dimension configuration is a product dimension and must consequently be specifiedplease help me in advance
It says that you must specify a value of the dimension. Do you have any problem with doing that?
thanks for replying martin its showing journal has not been posted. please help with this.
Yes, it's not posted because you still haven't filled in Configuration dimension. Please do it. The system won't let you continue without required data, no matter how many times you'll try it.
Hi, Martin.
I have faced this issue in the same scenario. also, I have checked from our end that specific item configuration. as well as I have checked this stores requisition configuration is already there in this field. moreover, I have checked the product dimension group master, it's only active for the configuration field. please find the screenshot and help me.
Item configuration and product dimension group
Stores requisition configuration
Product dimension group
Also, I have checked the related tables that configuration is there in those tables.
Can you please help me how to resolve this issue.
Thanks & Regards,
D.Mohan
