Enterprise portal "Error executing code: No system global variables"
Former Member
Enterprise portal Error
Microsoft Dynamics AX 2009: Error executing code: No system global variables (C)\Classes\WebLink\menufunction
I am getting this error on Enterprise portal as No global variables though I didn't change any code in AOT.
The enterprise portal stopped working after server restart.
The complete error is as below,
An unexpected error has occurred.
Microsoft.SharePoint.WebPartPages.WebPartException: Dynamics Object Adapter Call failed. ---> Microsoft.Dynamics.Framework.BusinessConnector.Session.Exceptions.XppSessionException: Dynamics Object Adapter Call failed. ---> Microsoft.Dynamics.BusinessConnectorNet.XppException: Error executing code: No system global variables.
at Microsoft.Dynamics.BusinessConnectorNet.AxaptaObject.Call(String methodName, Object[] paramList)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsObjectAdapter.Call(String methodName, Object param1)
--- End of inner exception stack trace ---
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.HandleException(String message, Exception exception, HandleExceptionCallback callback)
at Microsoft.Dynamics.Framework.BusinessConnector.Proxy.WebLink.menufunction(WebMenuFunction mf)
at Microsoft.Dynamics.Framework.Portal.UI.AxWeblink.GetWebLinkUrl()
at Microsoft.Dynamics.Framework.Portal.UI.AxWeblink.CreateActionLink()
at Microsoft.Dynamics.Framework.Portal.UI.AxWeblink.get_Link()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxWebMenuItem.get_Url()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.ActionMenuItemControl.Render(HtmlTextWriter output)
at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
at Microsoft.SharePoint.WebControls.MenuTemplate.Render(HtmlTextWriter output)
at System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer)
at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxToolBar.Render(HtmlTextWriter writer)
at System.Web.UI.UpdatePanel.RenderChildren(HtmlTextWriter writer)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxContentPanel.RenderChildren(HtmlTextWriter writer)
at System.Web.UI.UpdatePanel.Render(HtmlTextWriter writer)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts.AxBaseWebPart.Render(HtmlTextWriter writer)
at Microsoft.SharePoint.WebPartPages.SPChrome.RenderPartContents(HtmlTextWriter output, WebPart part)
at Microsoft.SharePoint.WebPartPages.SPChrome.RenderWebPart(HtmlTextWriter output, WebPart part)
at Microsoft.SharePoint.WebPartPages.WebPartZone.RenderZoneCell(HtmlTextWriter output, Boolean bMoreParts, WebPart part)
at Microsoft.SharePoint.WebPartPages.WebPartZone.RenderWebParts(HtmlTextWriter output, ArrayList webParts)
at Microsoft.SharePoint.WebPartPages.WebPartZone.Render(HtmlTextWriter output)
at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output)
at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer)
at ASP.DEFAULTAX_MASTER_1993109385.__Renderhtml(HtmlTextWriter __w, Control parameterContainer) in server/.../defaultax.master:line 115
at System.Web.UI.Page.Render(HtmlTextWriter writer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Please check the event log or contact your administrator.
Troubleshoot issues with Windows SharePoint Services.
Please help to resolve this issue
Related
Recommended
