How to define volume and Weight for Individual locations in AX 2012 R3 - WMS - please suggest a solution - reg
I want to define volume and weight for individual locations in AX 2012 R3 - WMS.
For this process, i need to define Height, Width and Length and Weight for individual locations
I also need to define height, width and length for items.
So that for each location, system should accept only the number of items which can accommodate in the particular location as per volume and weight defined.
If the volume and weight is reached for the particular location, then the system should suggest the next nearest location which can accommodate the items.
For example, if the location has defined weight of 50 kg and volume 50 units then once both weight and volume reached 50 and 50 then it should not allow the items in that location then system should suggest the nearest location.
I need the settings for these features in AX 2012 R3 WMS system.
Kindly consider this post and suggest me a solution.
Thanks and regards,
D Praveen Kumar.
Related
Recommended
