Work ID is not valid in Cluster picking process in AX 2012 R3 - pls suggest solution.
For Cluster Picking process setup,
I have created Location directives, Work template and Cluster profiles.
i have created mobile device menu item for Create cluster and Cluster pick
For this process, i have created 2 sales orders for different customers for the same item.
I have done confirmation of the 2 sales orders and i have done Release to Warehouse for the 2 sales orders
Different shipment is generated for each sales orders and single wave is generated
i have processed the single wave, single work is generated
Then when i doing Create cluster process in the mobile device menu option, i am getting the error as " Work ID is not valid" , when i try to copy the single work ID in the Work ID field in mobile device menu.
Note: I have used the exact warehouse in the Change Warehouse option. i.e , warehouse used in the sales transactions
Kindly consider this post , give me the suitable solution.
Thanks and regards,
D Praveen Kumar.
Related
Recommended
