Item Allocation key for demand forecast
I have notice one thing while assigning the item to the item allocation key, that one item can be assigned to the multiple allocation keys within the same company. I believe once the item is allocated to any allocation key it should not be available for any other allocation key.
Can you please advise is it the standard behavior? If yes then it will double the forecast.
Please advise.
Related
Recommended
