vendor global address
I have setup 2 companies.
In company A, i create a vendor XYZ with all related information.
In company B, i create same vendor XYZ, Ax prompt and as me whether to use the same vendor info and address. I select YES.
Now, AX link the vendor XYZ between company A & B by using the same partyid. If i change the address in A, it will auto reflect in company B.
Is there a way to split linkage between company A & B?
I want the vendor to operate independently by company.
thanks.
Related
Recommended
