Please tell the opening balances master tables for GO live
Hi All ,
 Before going Live,To Migratebalances from Legacy System to AX 2009 , Can you share me the minimum required fields and tables  Import process of opening balances of subledgers ( customer , vendor , item , bank , FA .) in AX 2009 through standard Wizard ?
Any MS manual or blog is availble ?
Thanks  in advance.
  • Import all of them into a general journal. The simplest way is to manual key one record from each and export the journal. The journal is then posted and everything is validated. .
Related
Recommended
