Data entity is not visible in other environments after package deployment.
Hello All,
I have created an entity in the dev environment and it was working fine there, but after moving the deployment to the test environment the entity is not showing up there.
The data management property is set to yes, also I have tried refreshing the entity list in the test environment.
Everything works fine in dev but once the deployment is done no entities are showing up in the test.
Please, anybody, suggest how to fix this.
Thanks!
Related
Recommended
