Number sequence event rule issue
We reached max systemId number sequence so I increase the max value, then ,I set an event rule on system Id  numberSequence to check how it increases. I deleted it and I still have a lot of generated records in eventCUD table. AX seem to continue logging system ids creation even if the relative rule doesn't exist anymore. I check all event rules table and I don't have any "ghost" records.
Related
Recommended
