Error installing AX 2012 AOS on a new server
When trying to install AX 2012 R3 CU9 on a new server, we are unable to install AOS component. It shows that the installation has succeeded, but when checking the log, we find error. Even the Service is missing. Error message shown is as below.
"2019-08-26 04:10:28Z    Granting AOS account access to database <model DB> on server <DB Server>
2019-08-26 04:10:28Z    ******************************************************************************************************
2019-08-26 04:10:28Z    Component installation task stopped due to an error.
2019-08-26 04:10:28Z    Attempted to perform an unauthorized operation.
2019-08-26 04:10:28Z    System.UnauthorizedAccessException: Attempted to perform an unauthorized operation.
2019-08-26 04:10:28Z       at Microsoft.Win32.RegistryKey.Win32ErrorStatic(Int32 errorCode, String str)
2019-08-26 04:10:28Z       at Microsoft.Win32.RegistryKey.OpenRemoteBaseKey(RegistryHive hKey, String machineName)
2019-08-26 04:10:28Z       at System.Diagnostics.EventLog.GetEventLogRegKey(String machine, Boolean writable)
2019-08-26 04:10:28Z       at System.Diagnostics.EventLog.FindSourceRegistration(String source, String machineName, Boolean readOnly)
2019-08-26 04:10:28Z       at System.Diagnostics.EventLog.SourceExists(String source, String machineName)
2019-08-26 04:10:28Z       at System.Diagnostics.EventLog.VerifyAndCreateSource(String sourceName, String currentMachineName)
2019-08-26 04:10:28Z       at System.Diagnostics.EventLog.WriteEntry(String message, EventLogEntryType type, Int32 eventID, Int16 category, Byte[] rawData)
2019-08-26 04:10:28Z       at System.Diagnostics.EventLog.WriteEntry(String message, EventLogEntryType type, Int32 eventID)
2019-08-26 04:10:28Z       at Microsoft.Dynamics.AX.Framework.Tools.ModelManagement.AxUtilEventLog.Log(EventLogEntryType eventLogType, AxUtilEventLogType logType, String message)
2019-08-26 04:10:28Z       at Microsoft.Dynamics.AX.Framework.Tools.ModelManagement.AxUtilEventLog.LogSuccess(AxUtil util, AxUtilEventLogType eventLogType, AxUtilAction action, IAxUtilEventLogEntry logEntry)
2019-08-26 04:10:28Z       at Microsoft.Dynamics.AX.Framework.Tools.ModelManagement.AxUtil.GrantPermission(String schemaName)
2019-08-26 04:10:28Z       at Microsoft.Dynamics.Setup.Support.SetupQueue.AOSInstaller.GrantAOSAccounttoDatabase(String databaseServer, String databaseName)
2019-08-26 04:10:28Z       at Microsoft.Dynamics.Setup.Support.SetupQueue.AOSInstaller.AosPreInstallActions()
2019-08-26 04:10:28Z       at Microsoft.Dynamics.Setup.Support.SetupQueue.AOSInstaller.PerformWork()
2019-08-26 04:10:28Z       at Microsoft.Dynamics.Setup.Support.SetupQueue.InstallationClass.DoWork(Object sender, DoWorkEventArgs e)
2019-08-26 04:10:28Z       at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
2019-08-26 04:10:28Z    ******************************************************************************************************"
Related
Recommended
