Transfer Order form loading issue in AX2012 R3 CU13
My client is using R3 CU13 and they are heavily using Transfer order form for stock transfer. When we open Transfer order form, the form opens and lags for 7 to 10 seconds before my cursor can move to another line. Although it is intermittent issue, most of the time we open encounter this issue.
I have tested in Standard R3 CU13 and it has the same issue. Our client is previously use R2 and they never have this lagging issue.
Please share your idea or work around solutions if you encounter the same problem before.  thanks in advance.
Myo
Related
Recommended
