Error: The DefaultValue expression for the report parameter ‘AX_CompanyName’ contains an error: The file exists.
Hi DAXers,
while trying to generate/run any report, system raising this error message:
Error while setting server report parameters. Error message: The DefaultValue expression for the report parameter ‘AX_CompanyName’ contains an error: The file exists.
 (rsRuntimeErrorInExpression)
I have already searched a lot about the cause of the error and the solution, but no one has broken into this point "The file exists."
Please, help.
thanks in advance.
Related
Recommended
