Table Content properties
What is the use of Table content property exactly, where it is used in realtime scenario (Default Data, BASE DATA, Default+Base Data)? What is the exact difference?
  • Specifies how setup/parameter data can be reused from one customer to another. The following values are possible:
    • Not specified – For most tables.
    • Default Data – Use for customer-independent data such as ZIP/Postal Codes, units, and time intervals.
    • Base Data – Use for customer-dependent data such as calendars, groups, and parameters.
    • Default+Base data – Use for data where the local perception varies. For example, Chart of Accounts is not customer-dependent in Germany, but is most other places in the world
Related
Recommended
