Connecting FinOps to an Azure subscription
Hi
I'm new to FinOps, and I've got the job to get our cyber security to allow a third party to develop using out instances etc. for a proof of concept project.
My question relates to the process where you link FinOps to azure. Is there any network level connection 'under the hood' when LCS links the two environments?
Thanks for any insights!
cheers!
davej
  • What kind of connection you're talking about? A web service?
    What kind of D365FO environment are you talking about? For example, is it a Dev environment that you've deployed from LCS to your own Azure subscription? Or do you use local virtual machines?
    You mentioned two environments - what is the other? Also, what do you mean by "LCS linking"?
Related
Recommended
