Getting time to move from one request to another (only in one partition)
Dear All,
When I move from one purchase request to another (All Purchase Requisitions), it is taking time.  We are using partitions and its happening only in one partition.
  • I would suggest having a developer to investigate the issue ( if you are not a developer). There are tools that can help you to identify the issue. (Example - AX Trace parser)
    Security in AX is specific to partition, so check if there are any data policies that are causing the issue?
Related
Recommended
