passing datasource record from form to menuitem class in ax 2012
I want to pass the current record from from to its menuitem button action class. How this can be achieved. Please suggest an answer in ax 2012
Thanks in advance,
Gopinath
  • void clicked()
        ImportExcel _import=new ImportExcel();
       _import.importExcel(ItemPriceSimulated.VersionId);
       info('Imported Completed. Check log file for error');
    Declare your class and pass the field value to ur class method as args like above and in class get the arguments
    void importExcel(CostingVersionId _ver)
    CostingVersionId _version       =   _ver;
  • In the Class Main method use arg.Record. Make sure u define the datasource for MenuitemButton in from level.
    server static void main(Args args)
         TableName tableName;
         tableName = args.record();
  • Hi Gopi,
    may be bellow code help full for you.
    public static void main(Args  _args)
        FormRun             caller;
        FormStringControl   fcsAllocationId;
        FormDateControl     fdsFrmDate, fdsToDate;
        FormDataSource      formDataSource;
        AllocationId  allocationId;
        date                fromDate, toDate;
        AllocationUpload upload = new AllocationUpload();
        caller = _args.caller();
        fdsFrmDate  = caller.control(caller.controlId("Allocation_FromDate"));
        fromDate    = fdsFrmDate.dateValue();
        fdsToDate   = caller.control(caller.controlId("Allocation_ToDate"));
        toDate      = fdsToDate.dateValue();
        fcsAllocationId = caller.control(caller.controlId("Allocation_AllocationId"));
        allocationId = fcsAllocationId.text();
        upload.loadingTimesheetData(fromDate, toDate, allocationId);
        formDataSource = _args.record().dataSource();
        formDataSource.research(true);
Related
Recommended
