How to check whether the object is customized or not through code in D365
I need to check whether the object(forms) is customized or not through the code in D365.
Example : If the object is customized means i need execute the condition 1,if not means the condition 2 need to be executed.
Anyone help me out to achieve the requirement.
Thanks in Advance.
Alex Jones AX
Related
Recommended
