Sales order form changes
Hi!
I added a cancel order button in sales order form, when we click this button sales order will get canceled but here I need to restrict that if any of the lines is delivered it will not allow to cancel the order..
My coding on Clicked method is:
void clicked()
    Dialogbutton db1,db2,db3,db4;
    if(SalesTable.SalesStatus==SalesStatus::Backorder)
        db1 = box::yesNo("Do you want to Cancel PO?", dialogButton::No, "Cancel Order");
        if (db1 == dialogButton::Yes)
            db2 = box::yesNo("This Will Cancel all the PO, no further activities is possible. Do you want to continue?", dialogButton::No, "Cancel Order Confirmation");
            if(db2 == dialogButton::Yes)
                SalesTable.SalesStatus=SalesStatus::Canceled;
                SalesTable.update();
                SalesTable_ds.refresh();
                info(strfmt("%1",SalesTable.SalesId));
    else if( SalesTable.SalesStatus==SalesStatus::Canceled)
        db3=box::yesNo("Do you want to Open PO again?",dialogButton::Yes,"Revoke Cancel");
        if (db3 == dialogButton::Yes)
            db4= box::yesNo("This Will Open all the PO again. Do you want to continue?", dialogButton::Yes, "Open Order Confirmation");
            if(db4 == dialogButton::Yes)
               SalesTable.SalesStatus=SalesStatus::Backorder;
    else
        info( "Process canceled");
How could I change my coding there to restrict the button from canceling the order?
Related
Recommended
