Error in Inventory Lookup and Customer Account payment In POS Retail AX 2012 R3
Hi All members ,
I am facing issue on LIVE environment of Inventory Lookup and Customer Account payment In POS.
In Inventory lookup and Customer Account payment I  am getting error as below:  As its very Urgent and its stuck on Production server so I need urgent help or I will ready to share my screen for Any help.
Another point can I get Customer Account payment without real time service as Inventory lookup and Cust account  payment is urgent requirement.
Thanks in Advance.
Regards
Sachin Kesarwani
Email sachinaxapta@gmail.com
1) I did  REALTIME  Service and website is working properly in both HQ and POS machine.
2) No certificate error as web site directly I can access in Both places and outside machine also.
3) I followed all blogs and multiple time Uninstall and install Real time service.
But still getting error: as per Event Viewer  messages.
Real-time service connectivity failure. The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:00:09.9535960'. Server stack trace: at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout,
LSRetailPosis.TransactionServices.EstablishConnection: System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:00:09.9535960'. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing) --- End of inner exception stack trace --- Server stack trace: at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing) at System.ServiceModel.Channels.SocketConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan Microsoft.Dynamics.Retail.TransactionServices.ClientProxy.ITransactionService.IsAlive() at LSRetailPosis.TransactionServices.CheckConnection().
LSRetailPosis.TransactionServices.EstablishConnection: System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Microsoft.Dynamics.Retail.Pos.Dialog.WinFormsTouch.formInventoryLookup, Text: Inventory lookup: System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Microsoft.Dynamics.Retail.Pos.Dialog.WinFormsTouch.formInventoryLookup, Text: Inventory lookup: System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:00:09.9535960'. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing)
regards
Sachin
Related
Recommended
